Negative Battery Terminal Getting Hot....
Old Aug 31, 2004 | 09:44 AM
SyKaTurbo's Avatar
SyKaTurbo
Default Negative Battery Terminal Getting Hot....
....During cranking over the the starter motor.
Is this normal to get a bit of heat or have a i got an earth problem somewhere? The wiring setup i have for the car has the battery earth cabled to the slam panel and the gearbox. The engine also has an earth from a bolt hole on the rear of the block to the chassis leg and the gearbox to the chassis leg. Do i need thicker cables or more cables.
Any help or advice appreciated as the last thing i want is an engine bay fire
Old Sep 2, 2004 | 07:36 PM
SyKaTurbo's Avatar
SyKaTurbo
anyone?
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
cameron2
Sep 6, 2015 10:40 AM
