T35 .55 + 430-450bhp?
Guest
Posts: n/a
Why dont people look into things better before claiming shit like that? lad currently has said turbo and around 340bhp, took the head off to freshen it up and his "tuner" has told him to swap the cams and slight headwork and he'll get 430-450bhp on the same turbo
I'm no cossie expert but I thought a .63 T35 running 30+psi would just scrape 400 but thats wringing its neck and probably wont last long.
What boost would be needed for 450 on a T4? early to mid 20's? and whats the best he can expect for that boost on that turbo?
Originally Posted by Rs1
I reckon you could make 400 on about 1.2 bar with high enough comp. ratio. Would it be reliable,i doubt it. Would it run like that on pump fuel, i doubt that too
I always thought there was 2 ways of making power......Low comp,big boost which normally seem power made low(er) down or high comp,less boost and rev the tits of it which normally makes power high(er) than the first way.
I'm far from being an expert on the subject though
so what's the advanatge of sean running this comp engine?
https://passionford.com/forum/viewtopic.php?t=232580
This might sound like a silly question but can you simply bolt a T4 onto an escort cossie and expect to gain mega bhp?
I'm not mechanically minded nor liked minded for that matter so don't know? but i was offered one recently at a good price and turned it down.
Not ability to rev but dont low comp motors tend to make power lower down?
Btw whats the comp ratio on your motor? Or is that top secret?
comp ratio on my car will be lower than probably any other on here and it makes peak powr at 8k which agan is probably higher than most on here, work that one out
the standard engine prob wouldnt last too long tho.
Originally Posted by Billabong
No, you'd need a remap and bigger injectors at the very least. With more engine work on top, you'd get more power.
you would get an increase in bhp if you set the boost as a higher level..
thats alot of help
yeah ive noticed you dont see many making figures like yours,max hp at 8k sounds pretty nice.
No worries about me half inching your spec.....i'm not building a cossie motor either just very interested as to why yours is making power where it is. Also interested in the lack of vacuum and cam spec but i doubt very much your gonna give anything away.
Yours being lower comp than most would make sense in terms of safety for extended periods of time at 100% throttle,what kinda egt's are you seeing?
PM me if you dont want it splashed across the boards
thats why its only 200 quid...
is useless really
thats alot of help
i would need to drive a high comp cossie to see what the benifits are on the road before i could comment fully on the difference between mine.
the EGTs and back pressure have been measured on the latest sesion on the rollers when geting it ready for the dady thrash.
EGTs are within acceptable limits thats all i can say
as for my spec..some people know it, some think they know it
will be some dodgy truck turbo then..
is useless really
is useless really
ive just got 403bhp on 28psi with a t34.63
Surely comp ratio does drastically affect power output, just as it does on N/A engines?
Running more boost on a low comp would be the same as running less on a high comp, all to do with how much mixture gets compressed and burnt?
although im probably wrong thought id ad my bit
Originally Posted by JTECHSAFF
what about a T38
PeterLucas Posted: Sun Nov 26, 2006 9:06 pm Post subject:
your not far off there, i run high comp and T38 as i want big power, but as its a road car i dont want the 5 day lag of a T4 lol
what about a T38
higher comp will give more power per boost pressure, but NOT much, esp as timing will prob need to be retarded more, and overall can run less, so car will prob have less power overall on pump fuel, hence the REASON people go low comp.
improves off boost power, but not hugely, not when it only 1point higher or whatever.
dont really affect lag or boost threshold.
dont know why seans doing it, prob for reasons that he will regret as its not all what the hype suggests.
engine advantages rollers, or nitrous?
Originally Posted by 392B.H.P.SAFF
t35 34psi 427bhp
Guest
Posts: n/a
PS
If you want to know the basics about understanding compressors, try this topic:
http://www.vauxhallsportforum.com/ph...urbos-t92.html
