What's wrong with my window?
Old Nov 25, 2006 | 09:07 PM
Paulo P's Avatar
Paulo P
Default What's wrong with my window?
My electric window on the drivers door of my sapph will go up but not down I've checked that there is 12 volts for it to go up and there is and I've also checked that there's 12 volts for it to go down and there is. Does it switch earths or anything silly like that?
Thanks
Old Nov 26, 2006 | 10:56 AM
righthooker's Avatar
righthooker
take the swiches out of the console and open them up it will be the contact ,i had the same problen and a mate of mine fixed it in 2 mins flat.
The switch has 2 little plastic rods they pop out now and then causing a bad contact.
Hope this helps
Old Nov 26, 2006 | 11:06 AM
Paulo P's Avatar
Paulo P
Cool. That sounds easier than changing the motor which I did yesterday What an arse of a job that was
Thanks.
Old Nov 26, 2006 | 07:47 PM
Paulo P's Avatar
Paulo P
I took the switch apart and gave it a clean and it sort of works now I think it needs a bit more attention because it's intermittent.
Old Nov 27, 2006 | 08:43 AM
TurboShed's Avatar
TurboShed
Cossiemodo
If your sunroof is leaking, and you have a manual sunroof, the water drips off the handle - directly above the electric window switches and corrodes them inside
Old Nov 28, 2006 | 12:02 AM
Grandad racer's Avatar
Grandad racer
did one for a mate, the switch woz full ov dust
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie330
Sep 27, 2015 04:13 PM
