HELP needed with suspension top mount removal........
Ive never had a car with these top mounts on before, any idea how i remove them??
i need them off as the whole car is stripped ready for shot blasting and paint
either use a C spanner in the 4 grooves around the edge, or make up a tool that fits in 2 of the 4 holes and get unscrewing - will probably be very tight, and you may have to grip the bottom under the inner wing
matman
Sep 9, 2015 05:45 PM
