anyone know about mitsubishi pajeros
Old Nov 24, 2006 | 05:51 PM
Trist's Avatar
Trist
Default anyone know about mitsubishi pajeros
as above 2.4 (i think) diesel old shape import, My mum had her other half change the turbo as it was fecked (no internals left) he replaced it with a decent second hand unit and in his wide experience after he fitted it he removed the inlet hose to the inlet housing and filled it with oil
Now as you can expect its a wee bit smokey. and about a month on nothing has changed. what can I use to get rid or stop it smoking or is there a chance that he has fooked the turbo??
Old Nov 24, 2006 | 05:59 PM
Puss2's Avatar
Puss2
Formerly know as Puss
Not sure about your question but this might help you out
http://www.pocuk.com/forums/
Old Nov 25, 2006 | 09:15 AM
James's Avatar
James
that would have filled all the pipes/intercooler/inlet with oil and it'll be smoking forever.
try disconnecting the pipe between inlet/intercooler and see if it still smokes as bad after a bit of running, be be carful of anything getting sucked into the pipes.
the intercooler is right on top of those engines iirc and not hard to remove, might be worth taking it off and seeing how much oil comes out.
Old Nov 26, 2006 | 12:14 PM
Trist's Avatar
Trist
nice one thanks will give that a go.
Big G
Feb 4, 2006 08:51 PM
wildheart
Jul 20, 2005 01:37 PM
jr
15
Oct 1, 2004 11:18 PM
jamieslittleracer
Jul 24, 2004 02:52 PM
