cylinder liners
Old Nov 24, 2006 | 05:20 PM
xr4x4rs's Avatar
xr4x4rs
Default cylinder liners
i have a 200 block here, and was wondering if its worth having it linered to return down to std bore size
it was bored out to 25th about 4 years ago as i was going to use cosworth racing pistons but change of plans i sold them and the blocks just been stood in my shed
the boresd have some slight suface rust on them
just wondering what sort of power a linered block could take
just std liners not nikisil
thanks
Old Nov 24, 2006 | 05:22 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
why not just have it de glazed to clean it up and use it at .25?
Old Nov 24, 2006 | 05:46 PM
xr4x4rs's Avatar
xr4x4rs
beacuase it looks like surface rust but im not to sure
its been in there quite a while
Old Nov 24, 2006 | 06:13 PM
bud-weis's Avatar
bud-weis
Football Cwazy
you could even bore it to .50 and have nice new standard pistons,still be strong enough for 400+
Old Nov 24, 2006 | 06:47 PM
xr4x4rs's Avatar
xr4x4rs
bud-weis
true, but would like std bore tbh
but have heard mix things about liners
Old Nov 24, 2006 | 06:48 PM
bud-weis's Avatar
bud-weis
Football Cwazy
ok,but my car is running .50 on a 205 block, and i have about 450bhp
and no me or Karl are expecting the block to split
Old Nov 24, 2006 | 06:59 PM
Escos Jam's Avatar
Escos Jam
Is it gonna be a big power motor mate ?? If so start again ... new block IMO
Jam
Old Nov 24, 2006 | 07:06 PM
xr4x4rs's Avatar
xr4x4rs
not big power, just a nice spec but reliable
at the minute my engine is std everything and has done 80k
i cahnged the headgasket to a 2 layer one and used ap studs and nuts
the bores still have honing marks in at 80 k lol
and the head has never been skimmed
but its a 205 block
so dont know wether just to use it until it blows up or just build a fresh engine using most parts from the 205 onto the 200
Old Nov 24, 2006 | 07:19 PM
Escos Jam's Avatar
Escos Jam
Ok mate lets be honest .. none of us stay st moderate power for long. get a new block on the way and you'l be`at big spec in no time ..
Jam
Old Nov 24, 2006 | 07:37 PM
xr4x4rs's Avatar
xr4x4rs
i know what your saying but i dont want to buy a block unless i have too
as i have 1 mint complete engine o the stand ready for stage 3
and a good 200 block and 4wd head in my shed
Old Nov 24, 2006 | 08:02 PM
xr4x4rs's Avatar
xr4x4rs
yeah but nikisil liners are £1500
but that sonly if you want to run mega power and stupid boost
ill be happy with around 400 but reliable
then ill just have to save up to buy the transmission
Old Nov 24, 2006 | 08:47 PM
bigad4x4's Avatar
bigad4x4
[quote="xr4x4rs"]
Tell me about it buy a spare set if goin 4x4
Old Nov 24, 2006 | 09:17 PM
xr4x4rs's Avatar
xr4x4rs
already have 2 gearboxes for 4wd
my car is 4wd
Old Nov 24, 2006 | 09:21 PM
rapidcossie's Avatar
rapidcossie
think 200 blocks are becoming hard to come by again..
maybe worth hanging onto it?
Old Nov 24, 2006 | 10:16 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Originally Posted by EsCosRacer
m8,
i had this discussion today with mike r.... unless going 500+ hp theres no sense in
even thinking about liners. if liners than surely nikasil ones cause their material
(nikkel, cadmium and silicium mix) has far better properties than using the cast
steel block to run pistons in and additinally prevents the block from cracking.
If you read in the ford mag about jenspeed, he also recommends nikasil liners for 500+hp.
cheers,
michael
you don't need nicasil liners for 500hp!!. ... or even 600 actually
Old Nov 24, 2006 | 10:24 PM
Jay,'s Avatar
Jay,
Sponsor
im runin 2.2 bar on a 100k 7.5 comp 205 block so stop panicing man theres loads of 205 blocks runing that power think brom run 500+ on one for ages
Old Nov 25, 2006 | 11:17 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Exactly,the 'weak' block thing is a little misleading really, BUT.......
being 4wd there will be extra stress on the block because you have a diff trying to rip itself off the side of the block putting a lot of extra stress on it,so consider that too.
if you have a 200 block then you may aswell use it
Old Nov 25, 2006 | 12:37 PM
JonnyBravo's Avatar
JonnyBravo
Is it not true that a bored 200 block is no better than a 205 anyway ?
My engine runs liners only due to the previous owner having a bit of a meltdown once.
I know of 2 500bhp engine running liners that have not been apart in 4 yrs, except for a turbo and one headgasket.
I dont know anything about liners or what they all look like but aren't some stepped at the top to stop the liner from dropping in the bore ? I have seen a picture of linered xe block where a unstepped liner dropped down and hit the crank
Some info on this would be good
Old Nov 25, 2006 | 12:48 PM
xr4x4rs's Avatar
xr4x4rs
the liners have to be stepped else it will do exactly how you said drop down
the company i use a lot do a lot of liners for jag,ferrari old skool blocks
all v8
basically they cut the old bore out to the size of the liner, also step the block so the liner sits in
next they heat the block up and the liners on in liquid nitrogen to shrink them or sumthing
once ready the bore is siliconed and the liner put into the block
the silicon id imagine is to stop oil coming up between the liners and block
then the liners are presed into the block
then the block is machined flat again and then bored to what ever size the pistons are
thsi is how i think its done from what ive seen but never asked how each step goes about
bud-weis
my engine came out f a 4wd car, but has a 205 block in
everything on the car was 4wd bar the block
hence asking if its worth changing blocks, but it means id have to have pistons
but would like it std bore
Old Nov 25, 2006 | 02:19 PM
Jay,'s Avatar
Jay,
Sponsor
what you bin quoted for a resleeve chap
Old Nov 25, 2006 | 02:46 PM
xr4x4rs's Avatar
xr4x4rs
havnt asked yet
Nov 1, 2015 06:53 PM
