little info
been offered this
t35 cosworth turbo, turbo technics stage 3 with cutback blades,360' bearing and a .55 exhaust housing for low lag
the thing i would like 2 know is what would i need to do for this 2 fit onto my S2
sorry to post hijack, but what exactly are cut back blades? standard ones cut down smaller to gain something, or at a different angle?
also 360 degree bearings? aren't all bearings 360 degreee?
please un confuzzle me
Cut back blades means the turbine impellor blades are trimmed back (usually bu 30 degrees). This gives more lag, but enables more power at top end. Turbo thrust bearings are normally 270 degrees, specially machined ones are 360 degrees.
Cut back blades on that turbo are a no no on RST, it'll be too laggy, and the exhuast housing is a little big too - better with a 0.48.
