which spark plugs?
Old Aug 30, 2004 | 08:39 PM
Jim Galbally's Avatar
Jim Galbally
Default which spark plugs?
motorcraft? NGK? bosch? champion? etc. etc. wot u recon?
n copper core, platiunum etc. etc.
v electrode, twin electrode, super4 etc. etc.
are they actually worth using? if so which type?
or shall i just stick to the ford jobbies at 70p each?
also does ne1 know what the std plugs are for the 24v granny scorpio? and also what one grae "cooler" are? (as i've been reccomended to go a grade cooler for n20)
Old Aug 31, 2004 | 08:51 AM
Jim Galbally
does anyone know about plugs?
i found out my std plugs are motorcraft: AGPR22C1
ive been reccomended to go a grade cooler and use plugs with a "retracted head"
what the fuck are these?
Old Aug 31, 2004 | 11:32 AM
Jim Galbally
after much discussion with some spark plug expet, i've decided on some BCR8ES and the best bit is theyre only 20quid for a set of 6
been told they may miss under normal driving conditions etc. tho so i MAY move onto either an NGK iridium plug (BKR7EIX) or a simple BCR7ES plug if it causes problems
Old Aug 31, 2004 | 11:33 AM
Rene's Avatar
Rene
jim is stu fitting/mapping the gas as well ?
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
