Leaky garage
Been thinking about getting a mint series 1 now for a while but i have a slight concern
My garage leaks
Now the water runs down the back of the garage, just in the corners and the roof soaks up the water also
So obviously when it rains you go in the garage and the floor is damp and it smells damp. I have got some tarpaulin up so any drips from the roof run down this and out towards the door
BUT, my question is............ will this have an effect on the car? Especially as it will be sat in the garage for about 8 months of the year
My garage leaks
Won't do it much good damp invites the old tin worm. If you're moving and don't want to fix the garage wait till you move.
Might be worth getting it sorted though as it shouldn't cost much and a dry garage will be a bonus when trying to sell up than a leaky one
My next house is being brought on the garage space or the space for me to build one.
It will definately affect the car mate!
I once parked my car in my parents garage, early october, car was very clean, bone dry and the garage didnt leak.
I went to check on it mid november and it was dripping with moisture underneath!!!
Could you fit a carcoon in the garage?
if it's got a flat roof then go down your local builders merchants and buy a tarp(Ł20-Ł30) big enough to cover the garage then weigh it down on the roof with bricks and secure it around the facia with 2x1 baton.
its a quick fix but will work
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
