group a t34.63 housing-247 maram shaft-360 bearings £900
as above im selling my group a harvey gibbs t34 from my rs turbo
PERFECT STRAIGHT FIT IF YOUR RUNNING A BRIAN HANSEN/JAMSPORT TUBULAR MANIFOLD
spec is
T34 + .63 REAR HOUSING
247 MARAM ANTI LAG SHAFT (stamped with 247)
360 BEARINGS
STRENGHTENED WASTEGATE ARM
QUICK RELEASE EXHAUST HOUSING
POLISHED/MACHINED OUT RESTRICTOR FOR FULL FLOW
NEW BEARINGS & SEALS ETC 550 MILES AGO BY FIELD MOTORSPORT
has actuator bracket welded to compressor housing as shown in pic so would possibly have to change depending what your gonna use it on.
NOW £900
note where actuator bracket is now located, was to allow me fitment of a brian hansen tubular manifold
no more pics at present as its still on the car as i dont wanna remove untill i know its gonna go.
spec is
360 BEARINGS
NOW £900
