2wd Cosworth Radio Loom
i know it's a pretty insignificant thing, but i want to fit my original Ford Radio in the cossie,but looking at the rear of my current headunit,the loom plugs have been cut off and rewired in to the existing headunit
so i basically need the plug that goes into the back of the standard headunit preferably with a decent length of wire attached to make fitment easier,oh and mine also has the ford amplifier fitted so i need the loom that will make both the standard radio and amplifier work together.
thanks
thanks
you knows it
the one i bought with the car is mint too, literally only used for a couple of years in the car.....although i very rarely listen to it anyway
but i want it to look standard inside,along with the amp that's currently doing nothing
STILL NEEDED
after being sent some by a very kind user on here...it turned out they weren't quite suitable
so if anyone has the correct plugs, with a bit of wire attached so i can connect them up, i'd be very very grateful.
this is for the FORD SOUND 2000 radio with seperate power amplifier..
please help
please help
Take a pic of the back of the HU and post it up. I reckon I know what ones you need, and I've got a set of them too
Are the speaker plugs a blade and pin type of plug?
Mines a different one agian!
I think this is the one you need, thats the power cable, but you'll still need the amp din plug. Get yourself to your nearest motorworld and order one of these:
big_Rad
Sep 15, 2017 09:36 AM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
