ZOO FUEL RAILS EXAUST BOXES 2ND HAND BITS !!!!
Old Nov 21, 2006 | 12:25 AM
CozzyBrom's Avatar
CozzyBrom
Default ZOO FUEL RAILS EXAUST BOXES 2ND HAND BITS !!!!
as above complete with standard down pipe with cat taken out 2/3rd system is magnex no dints or scratches on bottom
£160 deliverd
set 2wd konis with as new lowering springs £200
plain type billet alloy
-6 n -8 rails complete with cnc brackets £80 deliverd
plenum 10mm spacers £30 deliverd
ajustble top mounts alloy billet and pre drilled turret top adaptors to weld on £150 deilverd
cozzy pvc coated bradied hoses in blue black green clear red purple car sets tested to 250 bar
£50 deliverd or £15 each plus carrage
stanless back boxes double packed last longer and size bore n tail pipes £100 deliverd
middle boxes any size shape £110 deliverd
tail pipes £20 each for 4 inch
stanless bends most sizes £10 -£30 for 4 inch
stright tube exhaus most sizes from £10 a metre
Old Nov 21, 2006 | 03:56 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Hi broom.
How much, delivered to denmark, for an fuel rail with 10mm hoses to connect?
WERY interested
Old Nov 21, 2006 | 04:57 PM
CozzyBrom's Avatar
CozzyBrom
how long do you want the -8 lines
Old Nov 21, 2006 | 06:32 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Brom - How much would a Fuel rail and all hoses to do a Saph Cossie be?
I might take the car to 550bhp so need whatever size that needs (-6 or -8?)
I want to aeroquip it, but don't know what to order seperately so thought it would be best to order all of it from you. I have an 044 pump, so need an adaptor for that, then the hose to the rail, the rail, my 4*4 regulator, then aeroquip line for the return, plus whatever unions / connectors go with that lot!
Si
Old Nov 21, 2006 | 07:15 PM
JanDK's Avatar
JanDK
Hi Brom
Do you have any 14mm plenumspacers??
Old Nov 21, 2006 | 07:35 PM
CozzyBrom's Avatar
CozzyBrom
no mate carnt lazer cut 14mm ally due to thin wall
hence genesis charge more due to cnc machiing
they are the best to buy for 14mm
Old Nov 21, 2006 | 07:39 PM
CozzyBrom's Avatar
CozzyBrom
hi sib i qoute you a price on pm
so you want
12 banjo
16 banjo (filter)
18mm banjo (filter)
180 -6
1 4x4 rail adaptor
2 push fit pro clamps
8 metres hose
or would you like a earomotive reg with dash fittings
Old Nov 21, 2006 | 08:23 PM
cossiemanden
I have the lines, no problem, just want the rail to them
Old Nov 21, 2006 | 09:11 PM
CozzyBrom's Avatar
CozzyBrom
i will price it all up 2moz do you have the fittings or just the -8 pipe
Old Nov 22, 2006 | 09:04 AM
JanDK's Avatar
JanDK
Thanks you Brom.. I will decide what to choose then
Old Nov 22, 2006 | 05:57 PM
cossiemanden
I will also have the fittings, doesent have those.
Thanx m8
Old Nov 24, 2006 | 11:14 AM
Porkie's Avatar
Porkie
Brom I would like a Fuel Rail Please. Can you ask Martin what I need and get one to him please?
Thanks
Old Nov 26, 2006 | 03:47 PM
cossiemanden
any prices yet?
Old Nov 27, 2006 | 08:05 AM
G1EN's Avatar
G1EN
Hi Brom,
Im after a Fuel rail for T34 Escort Cossy and the aeroquip fittings/piping for both ends. Not usre which i need tho (-6 or -8) (Can anyone help here)
Hope that makes sense, i basically want to change the standard lot (Fuel rail and piping for an auroquip fitting rail..
Old Dec 4, 2006 | 12:10 PM
G1EN's Avatar
G1EN
Any idea when the fuel rails are going to be ready for a large turbo Escort Cossy.
Old Dec 4, 2006 | 04:19 PM
GARETH T's Avatar
GARETH T
you havent got any rear group n coilovers have you
ps i know im lazy
Old Dec 8, 2006 | 08:15 AM
JanDK's Avatar
JanDK
once again.. hey..
Are you still having some Escort Cosworth uprated suspension topmounts?? although I think it was you who made some
Dicko&Vacant
Aug 21, 2015 05:59 PM
Bailes1992
Aug 16, 2015 07:14 PM
Roosie
Aug 13, 2015 09:38 AM
muffster
Aug 12, 2015 08:14 PM
