Upgrading Springs & Bushes
Old Nov 20, 2006 | 10:05 PM
mondeo_mk3's Avatar
mondeo_mk3
Default Upgrading Springs & Bushes
Hi folks,
I am upgrading the suspension on my Mondeo and I have a few queries.
I plan to lower it using Eibach springs supplied by Ford, but I have been told that the rear subframe's on Mondeos are weak so is it worth upgrading to powerflex bushes?
http://cgi.ebay.co.uk/POWERFLEX-COMP...ORD-MONDEO-200 1_W0QQitemZ290050779738QQihZ019QQcategoryZ40192QQs sPageNameZWDVWQQrdZ1 QQcmdZViewItem
Apart from the prolonged life, what are the positives and negatives of this, will they make the ride harder as I don't want it too hard.
Secondly, while all of the suspension is out is there anything else I can do to improve the handling (without spending lots of dosh), anti-roll bar perhaps?
All comments are appreciated, thanks!
Old Nov 21, 2006 | 11:12 AM
mondeo_mk3's Avatar
mondeo_mk3
Old Dec 26, 2006 | 04:05 PM
rssteve's Avatar
rssteve
when you lower ythe car mate it normally puts more stress on the bushed as they sit at different angles, so uprated bushes will help it last longer.
Old Dec 26, 2006 | 04:34 PM
mondeo_mk3's Avatar
mondeo_mk3
thanks very much for replying this thread, its an old one but your reply was helpful.
Old Dec 26, 2006 | 04:38 PM
richard_syko's Avatar
richard_syko
ideally you would use a spherical bearing not a bush. Bushes allow for movement in just about every direction which changes geometry which in turn results in poor handling characteristics and tyre wear.
Poly bushes are stiffer thus reducing these effects.
Old Dec 26, 2006 | 07:46 PM
mondeo_mk3's Avatar
mondeo_mk3
Yup going for poly bushes by a company called powerflex (i think).
gcfcos
59
Oct 6, 2015 05:04 PM
Sp3no
Sep 27, 2015 07:23 PM
DavidK
Sep 27, 2015 02:55 PM
