help!!
Old Nov 20, 2006 | 07:10 PM
Fro Turbo's Avatar
Fro Turbo
Default help!!
where can i get a d/v or whatever it is that sounds like this!?? do i need to hav anythin special?
http://video.google.co.uk/videoplay?...77388&hl=en-GB
Old Nov 20, 2006 | 07:34 PM
Šhatter Box's Avatar
Šhatter Box
that ant a dv
its wastegate chatter ur never have it on mfi ur have to go efi to get it
Old Nov 21, 2006 | 07:42 PM
Chris69's Avatar
Chris69
i've heard it on mfi but to get full effect u do need an efi setup
the fiestas have it already due to uncle ford and his wisdom
Old Nov 21, 2006 | 09:11 PM
SafeChav's Avatar
SafeChav
Sorry.....it's what did you say....?
ohhhhhh TURBINE STALL.......i swear you said wastegate chatter
There are plenty of MFI cars that have been known to do it, its not ever as good as on an EFI car though because the flap on the metering head closes and deadens the sound .
Old Nov 21, 2006 | 09:29 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
its compressor stall ur never have it on mfi ur have to go efi to get it
Mine chatters on mfi with std airbox
Old Nov 21, 2006 | 10:38 PM
addiction's Avatar
addiction
ohhhhhh TURBINE STALL.......i swear you said wastegate chatter D .
it's compressor stall actually
Old Nov 22, 2006 | 02:49 PM
SafeChav's Avatar
SafeChav
A compressor is still a turbine
Old Nov 22, 2006 | 04:05 PM
addiction's Avatar
addiction
but the correct terminology aint "turbine stall" its compressor stall
Old Nov 22, 2006 | 06:29 PM
Fro Turbo's Avatar
Fro Turbo
sounds wwwwwwaaaaaaaaaaaaaaaaaaaaaaayyyyyyy too fuckin complicated
Old Nov 22, 2006 | 09:39 PM
SafeChav's Avatar
SafeChav
The sound is the compressor stallin granted, the compressor by definition is a Turbine.
So therefore turbine stall is not gramatically incorrect
Old Nov 22, 2006 | 10:27 PM
Rick's Avatar
Rick
Mine CHATTERS ITS ARSE OFF on Mfi... And no, the spring isn't fucked! Must be big turbo combined with big cooler
Old Nov 23, 2006 | 12:03 AM
vroooom ptssssh
It Wasnt Me!
Rick, I reckon once my boost is wound up mine will do the same, but for 7psi it chatters good
Fro Turbo, It's simple, take your D/V off, blank the 2 hoses with broom handle for the big one, a bolt for the small one, or jus take it and the Tpiece off and connect back to inlet and give it some right foot/lift off an see what it does
Old Nov 25, 2006 | 05:42 PM
sheps's Avatar
sheps
i tryed the above technique and got no sound at all, was very strange to hear nothing!
Old Nov 27, 2006 | 05:18 PM
Fro Turbo's Avatar
Fro Turbo
i dont hav a d/v, infact i dont hav squat its all totally standard but iv got a fucked up problem where it just doesnt want to do much after 3000ish rpm n even on its way there its a bit lumpy. been like that since i got it (2 months or so) n i think it might be the spring on the wastegates fucked? was just gunna leave it n put on a -31, chip etc etc over winter then get it set up but i heard ur best makin sure the engine is sweet before u start tuning them?
not sure whether or not to tune it cuz its all standard n pretty mint with a fully backed up 71k, but on the other hand, im 19 n its what iv always wanted. pullin my frickin hair out tryin to decide what to do!
Old Nov 27, 2006 | 07:05 PM
SaqsS2turbo's Avatar
SaqsS2turbo
actuator
Old Nov 28, 2006 | 04:43 PM
Fro Turbo's Avatar
Fro Turbo
u reckon? or u know? any information or advice would be a great feckin help!
