mfi rst fuelling ??
Nov 20, 2006 | 01:35 PM
mfi rst fuelling ??
is the mfi system on a esc rst capable enough of fuelling a 1.8 zvh correctly ??
or would i need a 5th injector fitting ???
Nov 21, 2006 | 01:54 PM
Think you will need a 5th injector or changing your management to efi so you can fit bigger injectors.
Dave
Nov 21, 2006 | 09:30 PM
You might get away with running low boost on a 1.8
But as said.......the all round better option would be EFI. MFI is poo
Nov 22, 2006 | 09:25 AM
Quote:
Double that
As on 2.0 zvh you can run 10 psi or even 12 psi with EFPA tweaked
A.t.p
Oct 23, 2015 07:54 PM
Chas
Oct 5, 2015 07:13 PM
Billy_RS
Sep 13, 2015 04:17 PM
stevierob
Sep 7, 2015 07:09 PM
