How do i change the foglight bulb
Old Nov 20, 2006 | 01:34 PM
llw's Avatar
llw
Default How do i change the foglight bulb
right one of my bulbs in the cossie foglight aint working
anyone know how do i change it
its a saph btw
thanks
Old Nov 20, 2006 | 07:54 PM
Daveesaunders's Avatar
Daveesaunders
Theres a small screw holding the plastic cover on at the top, this then pulls off revealing the enitire lamp unit which you'll need to remove by undoing the screws either side, this will allow you to remove the unit and access the back of the unit so you can take the bulb out.
And as the Haynes manual would say "re-fitting is the reverse of removal"
Old Nov 20, 2006 | 10:41 PM
llw's Avatar
llw
so the plastic cover does come off then
any ideas where this screw is, as i cant see it
Old Nov 21, 2006 | 03:04 PM
Smoker's Avatar
Smoker
Default fog light
take it to kwik fit
Old Nov 21, 2006 | 06:43 PM
Daveesaunders
The screws along the top edge in a hole, you'll need to pull the top edge towards you when removing as theres a couple of lugs along the bottom edge.
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
