Anyone got a sierra front hub or disc handy?
Could you measure the outside diameter of the hub or the inside diameter of the disc? I need to turn a capri hub down to fit cossie discs to replace my knackered hub but don't want to take it all apart untill i've had the machining done.
inside of the disc measurement
but there is a bit of rust on the inner lip so you may be able to leave it a little bigger by 1 or 2 mm
can't do any more beause of my condition sorry
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
