how much boost would you run though my engine
cosworth yb
cosworth 4x4 forged low comp pistons
arrow h beam con rods
full lightened and balance bottom end
ported and polished head
swidish inlet
wrc spec 200 block
i know this is a sort of dumpassed question but i want a sort of rough idea
swidish inlet
wrc spec 200 block
Originally Posted by jon@work
what turbo ?
what compression ?
what compression ?
and it hasn't got a urbo yet. one i find out how much boost the engine would take i can then decide on a turbo
psi is dependant on turbo entirely.... decide what power you want, and where you want it in the rev range then spec your turbo to suit. A GT30 sounds like the sort of thing you are after
Zoggon
Aug 10, 2015 10:39 AM
