Can i use 200 eng. cams on a 205 eng.??
Old Nov 19, 2006 | 08:45 PM
Super5's Avatar
Super5
Default Can i use 200 eng. cams on a 205 eng.??
Hi
I building up my 2wd. cossie engine
I tought they where different.
Old Nov 19, 2006 | 08:49 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
I think that what u are refering to is the block.
The 205 block is a little bit weeker then the 200 block, but it`s the same design.
Everything that goes with the head is the same in all engines, accept 2wd heads and 4wd heads are a little bit different cam wise.
Hope it helped
gurnE's Avatar
gurnE
2wd and 4x4 cams are different.
You can run one in the other with a spacer but I forget which way round it is.
I'm sure someone on here will know though
Old Nov 19, 2006 | 08:54 PM
Super5's Avatar
Super5
I Mean 2wd head and a 4wd head.
A friend has 4wd bd10 cams for sale so i was wondering i can use them for my 2wd saph.
Old Nov 19, 2006 | 09:10 PM
The DIVA's Avatar
The DIVA
You can use 4wd cams in a 2wd head but you need spacers for the front,I suggest you contact Mike Rainbird @ R+B motorsport....he will be able to locate them for you...
Old Nov 19, 2006 | 09:27 PM
david's Avatar
david
never knew they were different.
learn something every day
Nov 1, 2015 06:53 PM
chowfornow
Alloy wheels and ICE for sale
15
Oct 17, 2015 07:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
20/20 vision
Sep 29, 2015 11:27 AM
