cosworth , rocker cover gasket prob
As aboe , got my rocker cover powdercoated and ive not had the car that long really , but previously on removing it , i was shocked to see no gasket fitted
Anyway fitted new gasket on fittting rocker cover , and my problem is , where number 4 spark plug is (at back of engine) is filing with oil ? like the 4 areas around it if you know what i mean
car runs fine and has done for the last week and a half that its been back on road ~?
Took of rocker cover and cleaned oil up and took plug out gave a check and im ready to put rocker cover back on now ?
Any ideas ? the gaskets still in place and to me looks ok ? it is a new gasket from woodford
any tips or ideas people ?
Originally Posted by rabmc
Think so mate , its the 4 bits that sit around where the plug sits ?
Why did this result in a rebuild mate ? what happened ?
Could be that your cam cover is not flat as when things are powder coated they are put through a oven this can twist objects because of the heat better of getting it skimed then you wont have any probs mate
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 14, 2015 07:29 AM
