shaky series 1
hi just had a new gearbox put in and a s2 flywheel and clutch
the car is fine when driving slow but as soon as you get higher up in the revs the car starts juddering at the front as if the front is going to fall off and when letting off the power in fourth at about 4 thousand revs it shakes the ehit out of the car anyone got anyideas what is causing this
cheers ben
cheers ben
if i were you, i would double check:
all suspension bushes and bolts,
TCA's
wheel bolts
drive shafts and make sure they are locked in and not just pushed in place
the big bolt that holds driveshaft against disc
calipers
double check gearbox bolts
for some reason, if above seems ok...i would suspect a dodgy flywheel but it would also do it on take off to...
bassboy
TCA's
wheel bolts
calipers
bassboy
Originally Posted by gup
the shim inbetween the block and g/b is still in place and hasnt fell off when you took the flywheel of has it as this will cause a vibration
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
