cossie clutch plates
Old Aug 30, 2004 | 10:42 AM
markk's Avatar
markk
Default cossie clutch plates
does anyone know if the clutch centre plate is teh same on the 2wd and the 4wd ??
its that long since ive even seen a std clutch plate i dont know if there the same , will the 2wd unit work ok with the 4x4 flywheel and pressure plate ???
cheers
mark
Old Aug 30, 2004 | 10:56 AM
Alvyn's Avatar
Alvyn
mine has a centre plate from a 4x4 and it works fine
RB26DETT
Feb 5, 2022 01:54 PM
yatta
May 21, 2016 10:31 PM
landaqmabba
Sep 15, 2015 07:16 PM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
