rear disk conversion.
Old Nov 15, 2006 | 10:30 PM
addiction's Avatar
addiction
Default rear disk conversion.
thinking of doing this at the monment but would be nice to know if it is really worth it? and do you have to have a bias valve to stop it swapping ends under heavy breaking?
Old Nov 16, 2006 | 03:31 PM
SafeChav's Avatar
SafeChav
Thats gota be a first you asking the questions
I think the general view on it is that when you are, and i quote, "take the piss braking" then things can get a little hairy.
And fitting discs on the back is when you start increasing the travel on the pedal, the pistons are massive for rear calipers.
On the plus side, they look the tits...... and changing pads is easy
Old Nov 16, 2006 | 03:48 PM
Marc LJX's Avatar
Marc LJX
I had them on my S2 for 5 years, but just went back to drums at the beginning of this year due to a change of wheels (I needed the rear wheels to sit a little further in to stop fouling the arch).
IMO they are more for show than go, so i wasnt too sorry to take them off.
You can adjust the severity of braking with the load sensor valves easy enough, best done on an MOT brake tester, so you shouldnt really need a bias valve.
Just get them set up so they brake as much as the drums used to...
Handbrake was always shit on mine though, nowhere near as good as the drum handbrake...
As Safechav says though, they look the tits!!!
Old Nov 16, 2006 | 03:51 PM
SafeChav's Avatar
SafeChav
Marc LJX, you probably don't want to hear it but there are ways to stop the discs pushing the wheels out, mine are only a coouple of MM spaced out now.
But mine being a MK3 they still didn't clear the arches, on a MK3 the ONLY way is to have the arch modded. And alike....mine doesnt have variable load valves.........
Old Nov 16, 2006 | 04:10 PM
mercury grey minter's Avatar
mercury grey minter
DISCS FOR SHOW
DRUMS TO SLOW.
Old Nov 16, 2006 | 04:14 PM
addiction's Avatar
addiction
pmsl i'm good, but i dont know everything
Old Nov 16, 2006 | 04:15 PM
Marc LJX's Avatar
Marc LJX
SafeChav, how do you make them not space the wheels out so much?
Do you have to get the hubs machined or something?
Old Nov 16, 2006 | 04:22 PM
Micky's Avatar
Micky
Originally Posted by mercury grey minter
DISCS FOR SHOW
DRUMS TO SLOW.
Which is why every modern racecar runs drumbrakes!!!!
Old Nov 16, 2006 | 04:28 PM
SafeChav's Avatar
SafeChav
DISCS FOR SHOW
DRUMS TO SLOW.
PMSL We have an RS geek among us it would seem
Awww too bad........i do
Basically yeah........ theoretically you could quite easily bring the wheels fully back but personally i think you can only re-gain so much before you start compromising safety
Old Nov 16, 2006 | 04:34 PM
Marc LJX's Avatar
Marc LJX
Definately yeah, but how do you know how much to safely take?
I have been known to do the occasional trackday...
If one of the hubs failed that would see some serious end swapping action
Old Nov 16, 2006 | 05:10 PM
bassboy's Avatar
bassboy
i have a set of brand new discs, pads, 2nd hand calipers, hubs for sale if your interested...only thing u need is a cable and the brakets
im only after Ł120 for the lot
bassboy
Old Nov 16, 2006 | 08:34 PM
mercury grey minter
DISCS FOR SHOW
DRUMS TO SLOW.
Please don,t compare a 15 year old ESCORT RS TURBO to an up to date RACE CAR.The stopping efficienncy of REAR DISCS over DRUMS on an ESCORT is minimal.
Also note the ammount of exclamation marks iv,e used to show my rage.
Old Nov 16, 2006 | 09:05 PM
SafeChav's Avatar
SafeChav
I noticed the punctuation you used cos you can't spell
Old Nov 17, 2006 | 06:15 AM
Maki's Avatar
Maki
Braking on RST is mostly done by front brakes. It doesn't really matter what you have in the back. I would stick to the drums as the handbrake works better on them
Old Nov 17, 2006 | 07:27 AM
Marc LJX's Avatar
Marc LJX
As above
Depends if you want brakes that look good, or if you want to do handbarke turns on dry tarmac
Old Nov 17, 2006 | 11:10 AM
John Laverick's Avatar
John Laverick
I much preferred the discs on the rear of mine to drums:
a) The handbrake was far superior! You can easily lock both rear wheels for a swift handbrake turn which I could never do with Drums
b) Much easier to change pads which is important when doing a few track days
Also, the bias valve is a must!
Old Nov 17, 2006 | 12:00 PM
ivorbiggun's Avatar
ivorbiggun
Once set up correctly (no one else seems to have mentioned this) the front
of the car doesn't dive as much with disc's. Which, apart from (subjective comment alert) 'slightly better' braking is the nicest effect.
But if anyone is considering this conversion it's essential to steel braid all the hose AND remove the scs pumps and ALL the rubber hoses that run to+from
them to enjoy 'proper braking'. ........I.M.O. obviously gents.......
Old Nov 17, 2006 | 12:47 PM
Wazzzer's Avatar
Wazzzer
my mate changed his to discs on the rear and was always wary of the arse end coming out...
I changed mine AND the fronts, removed the ABS and braided the lines. Never had a problem, I think thats the key really
and totally agree with John, the handbrake is lovely, just make sure you put it on with the foot brake pressed down when you park up after a spirited drive, if not it can lead to your car rolling away
Old Nov 17, 2006 | 05:55 PM
mercury grey minter
What sort of name is fucking SAFECHAV anyway.........
Old Nov 17, 2006 | 07:05 PM
SafeChav's Avatar
SafeChav
Mine it would appear
Have you consider changing yours to SafePunctuation
Old Nov 17, 2006 | 07:40 PM
mercury grey minter
Short
And
Fat
Eccentric
Clearly
Has
A
Vagina.
That,s what your name really means.
Old Nov 17, 2006 | 09:09 PM
NUTS RuS's Avatar
NUTS RuS
Someone else knows him well then
Mine has disc's because they work and are designed to do just what ivorbiggun posted.
Car brakes from all 4 corner and keeps it level which is essential when left footing it round corners
Old Nov 17, 2006 | 09:52 PM
Rick's Avatar
Rick
keep em small though eh tony...
Old Nov 18, 2006 | 12:29 PM
16vzetec's Avatar
16vzetec
i got sierra rear disc's and the are too powerfull, you need bias valve.
drums work fine but look crap
Old Nov 18, 2006 | 02:47 PM
NUTS RuS's Avatar
NUTS RuS
I run bog standard sierra rears with the cheapest pads i can find too
Old Nov 18, 2006 | 06:01 PM
marky_g's Avatar
marky_g
Fleet Manager
if u car aint that powerful and i dont drive i nob drums are ok
othrewise its proper break time
Old Nov 18, 2006 | 06:05 PM
Marc LJX's Avatar
Marc LJX
Must admit i never really put too much effort into setting mine up properly...
Must try harder next time...
Old Nov 19, 2006 | 09:22 AM
GUZZLER's Avatar
GUZZLER
i've had disks on a few rst's, i don't have problems with them, as said because the rears are braking more it stops the car diving as much, plus i hate drums, akward to work on & look a bit tat.
Old Nov 19, 2006 | 07:22 PM
stuartrst's Avatar
stuartrst
handbrake ok on mine looks better than drums and quicker pad change over. i would do it again.
Old Nov 19, 2006 | 09:20 PM
SafeChav's Avatar
SafeChav
Short
And
Fat
Eccentric
Clearly
Has
A
Vagina.
Hmmmmm i'm still seeing some problems
To make it easy for you ive highlighted the punctuation error and MISSING word
155lee
Sep 6, 2016 11:10 AM
yatta
May 21, 2016 10:31 PM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
