plumbing help (compression joint)
do the nut up mate! It pushes it into the joint and it squeezes the olive onto the pipe. could use a bit of jointing paste if you want to make sure it seals but its not necessary.
hope it helps!
hope it helps!
i hate it when plumbers use jointing tape ... no need for it unless they are too heavy handed
last one that did it on one of my jobs caused the client to be charged around £600 labour for me to flush it out of their coffee machine
bet i charge more an hour than tiff does
If theyre bad enough to be able to get it inside the pipe when putting it on then they shouldnt be in the job really should they?
I said jointing paste anyway!
you dont use tape on compression joints.
i know
it was nearly a case of pulling the machin out it had got caked up in the water filter and electrovalves
oh also £200 for another water filter forgot that
they of course denied all responsiblity .. but as it was on a quinetiq site they could not get out of it
everything is documented .. bloomin military
i put ptfe tape on all the joints
and the stuff the pipe in as far as it will go before tightening up the nut
you can normally get it tight enough with your hand and then as you tighten it up with the spanners they start to bite
you can also "feel" when the olive has got tight enough once you've done a few
Originally Posted by andyh4324
crazy! Just for bit of stuff in the pipe!
i always use a water jointing paste(jet blue)around the olives and have had no problems
if you put it on the inside of the pipe thats another story
Originally Posted by simhopper
compression fittings nowadays are pi55 poor
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
