Best suspension set up for big turbo Escort Cosworth?
zoo rear beam is a cracking buy and worth having if you want a cossie to handle really well!
as for shocks, depends really what you wanna do with it?
road diving with track days every now and then,, i would say a set of koni's on a tidy set of springs, but if you want a propper track day weapon you billies you cant go wrong with
Coilovers are wicked for track use but very harsh for a road car......
This week we changed suspension on an Escort Cossie from coilovers to Konis coz the guy was fed up with the "ride" of the coilovers...
If you want a nice handling road car for occasional track use the setup above I suggested will be spot on...as most people will agree
or
If you want a track monster go for a Zoo rear beam, adj TCA's, coilovers etc but you will need a much bigger budget
or
In my appinion, the koni`s arent that good...
I`m using the bilstein damper and eibach springs, and it`s much more slim on the track then the koni`s...
My appinion is that the koni`s is just hard, and pretty hard to set up correctly, while
The bilstein`s is MUCH MUCH better.... both on the road and on the track...
It seems like the bilstein just sucs on to the road
Escortdriver1
Jul 31, 2015 02:36 PM
