FAO Stu @ MDev
Old Nov 13, 2006 | 06:18 PM
Stu.H's Avatar
Stu.H
Default FAO Stu @ MDev
Evening Stu
Ive recently bought a 306 XLDT as a run about.
Dont want mega power from it, but I heard you can do stuff to it to increase power and improve economy?
Can I have some numbers please, price, power increase and how long you would need the car for? Also is it worth doing?
Cheers matey
Old Nov 13, 2006 | 06:22 PM
SapphyMike's Avatar
SapphyMike
Old Nov 13, 2006 | 06:23 PM
The DIVA's Avatar
The DIVA
http://www.remapping.co.uk/
Look here Stu you lazy git.....
Old Nov 13, 2006 | 06:36 PM
gurnE's Avatar
gurnE
Getting a error message on your motorcycles & focus RS pages btw Stu.
Not Found
The requested URL /~motorspo/pages/focusrs.htm was not found on this server.
Apache/1.3.37 Server at 60gp.ovh.net Port 80
Old Nov 13, 2006 | 06:46 PM
Stu.H's Avatar
Stu.H
Had a read of 'remapping.co.uk', is there a chip swap I can do, or is it best to get the full remap?
Is boost increased slightly on the remap, or just the chip and setup suffices?
Thanks for the replies, apart from u sapphymike u coont lol, I know his number but as he frequents on here, I thought Id ask the question
Old Nov 13, 2006 | 06:51 PM
Zetec Andy's Avatar
Zetec Andy
Category 1: Mechanical TDi
This engine can achieve good results, typically up to 30 BHP and 30% more torque, however, due to the mechanical pump not being controlled to very close tolerances when initially accelerating, some smoke may have to be tolerated while the turbo is producing initial boost. A free flow air filter will help this problem a lot.
On this type of system we can modify the diesel pump timing and fuel delivery along with an increase in boost pressure to match the extra fuel. This will give much improved throttle response and mid range torque.
Example:
Peugeot 306 D Turbo (intercooled)
This vehicle gains approximately 25 Bhp and 31 Ftlb of torque, giving this great little car hot hatch performance.
Its also worth noting that these improvements are on a vehicle giving perfect factory power already. If your vehicle is out of tune and down on power, you will gain more power than stated.
The cost of this work is Ł250 inc vat.
Old Nov 13, 2006 | 06:53 PM
Stu.H's Avatar
Stu.H
Im sure I read elsewhere that a live map is 350?
Old Nov 13, 2006 | 06:56 PM
The DIVA's Avatar
The DIVA
You can`t map them old nails Stu....
Mechanical mods to the pump timing and boost...
Old Nov 13, 2006 | 06:57 PM
Rick's Avatar
Rick
It's not a Live Map in the sense that Stu needs to completely rewrite the map for different injectors etc, where he needs the car for a week minimum. It is done live though - as in all the monitoring equipment is attatched to the car and it is driven to check everything.
Call Stu, he'll happily tell u everything u need to know.
Lee_R21Turbo's Avatar
Lee_R21Turbo
AFAIK - the Pug Turbo Diesel engines require the fueling & boost increasing mechanicly as they do not operate from an ECU - the HDIs however do.
After the fueling etc tweaking you should see about 115bhp & a hefty increase in torque too!!
I'm sure Stu will verify all this!!
Old Nov 13, 2006 | 06:58 PM
Stu.H's Avatar
Stu.H
Yeh might give him a buzz if he dont see this post...
I owe my lad a weekend away, 2 birds one stone and all that
Old Nov 13, 2006 | 08:23 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hin Stu,
The pump is indeed mechanical and Andy quote sums it up nicely pal.
It takes approx 4hrs to do mate.
Old Nov 13, 2006 | 08:46 PM
Stu.H's Avatar
Stu.H
Wicked.
Let me get my ZVH bill out the way and I'll call you to book it in
Thanks for taking the time to reply, appreciated!
Old Nov 13, 2006 | 08:58 PM
Your welcome.
GTR_STU
Aug 28, 2015 01:02 PM
Bailes1992
Aug 16, 2015 07:14 PM
