Metering head question weird
Old Nov 13, 2006 | 12:28 PM
davidnormanuk's Avatar
davidnormanuk
Default Metering head question weird
This is a funny one.
Pulled up to a cashpoint turned the car off and locked it up. Came back 5 minutes later went to start the car and it wouldn't fire at all. Spark was there and there was fuel going to the Metering head but nothing was going to the injectors. Checked all sensors etc and found everything to be connected as it should be. Got my mate to tow me home and he suggested trying to bump it off while he towed me. This did the trick straight away no stuttering or anything. Car has run spot on since which is weird.
Could I have just had an air lock in the system?
Dave
Old Nov 13, 2006 | 02:12 PM
gup's Avatar
gup
sounds like the flap in the metering head is sticking thats what my brothers series one did i cleaned all around the flap and it was allright after that
Old Nov 13, 2006 | 02:17 PM
davidnormanuk
I took the filter off when the car wasn't starting to see if I could prime the system by pressing the flap down slightly but no fuel came through. Can't do any harm to double check everything is clean though.
Dave
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
kevin36
Sep 9, 2015 11:12 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
kevin36
Sep 8, 2015 12:23 PM
