Faulty abs pump , would it...
Old Nov 12, 2006 | 02:01 PM
rabmc's Avatar
rabmc
Default Faulty abs pump , would it...
Would it cause a fuse to blow ?
My pump is knackered i think , as pedal goes hard after ive been driving around for a while ,its done this for a while but is somethimes ok , but as some of you already know , had alot of engine parts off , cleaning etc , now when i connect one of the main plugs onto pump , it blows this fuse why would it do this peeps , got a multimeter but whatr kind of readings should i by looking for , the plugs has 5 pins if i remember right , so cant put it in the wrong way
thanks again
hate electrics man !
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
