Fuse keeps blowing! pics added !! help
Old Nov 11, 2006 | 12:42 PM
rabmc's Avatar
rabmc
Default Fuse keeps blowing! pics added !! help
As above basically me car keeps turning over but will not start 3 door, now it was dark and i turned ignition on for first time in neary 2 weeks and i seen a flash/fuse blowing down above my pedals
So basically my engine bay was getting a refresh and tidied up some exposed cabling here and there with new tape and everything went fine i think , could be totally unrealated , but thats 2 fuses now 30A and both have popped once i turn ignition on
Heres a pic of where it lives and i have no idea if this is why its not starting or what the hell this fuse does
Any help appreciated , and any ways of testing/with multimeter would be great
Here is the bugger that usually sits i the green holder
Old Nov 11, 2006 | 04:04 PM
jon@work's Avatar
jon@work
have you removed the wiring plug from the ABS pump and refitted it the wrong way round, or is that fuse deffo for the engine management (think both my management fuse holders are yellow, but I may be wrong) ?
Old Nov 11, 2006 | 04:07 PM
rabmc's Avatar
rabmc
Mmm good question , did have those plugs off
Starting problem sorted though . refilled my power steering fluid and my wheel started turning slightly by itself and making a screeching noise ? Luckily it aint moving at the moment
Is that fuse something to do with the abs then ???
Old Nov 11, 2006 | 04:25 PM
jon@work's Avatar
jon@work
there is a fuse down there for the ABS pump - get a multimeter between the plug on the ABS pump and the fuse holder and check for continuity
Old Nov 11, 2006 | 04:28 PM
rabmc's Avatar
rabmc
Il disconnect my plugs and re-new fuse to see if it still blows then get the meter in about it
Old Nov 11, 2006 | 05:07 PM
jon@work's Avatar
jon@work
good plan
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
pabloXR
Sep 21, 2015 12:42 PM
Flatlinedan
Sep 18, 2015 12:41 PM
Rammer46
Sep 18, 2015 08:31 AM
