Timing Out?
Old Aug 29, 2004 | 01:36 PM
avengerpenguin's Avatar
avengerpenguin
Default Timing Out?
Will a cossie engine start if the distributor timing is a tooth out?? and what would it run like if it would start?
Old Aug 29, 2004 | 01:46 PM
dave green's Avatar
dave green
Proberly would start. but it wouldent run very good.
Dave
Old Aug 29, 2004 | 02:10 PM
Disabled Account's Avatar
Disabled Account
avengerpenguin,
Will tend not to "catch" properly when starting, slight delay
i.e. wont fire up straight away as usual.
Will run OK (ish)...but needs sorting a.s.a.p.
Old Aug 29, 2004 | 02:14 PM
avengerpenguin
It starts fine so I guess its right its just that ive put this new head on its ported and polished and running bd14's and it runs rough off boost, quite "jumpy" and spluttery when constant cruising throttle
Old Aug 29, 2004 | 02:21 PM
Disabled Account
I would check it carefully........check the timing again, and everything else too, just to be safe.
Old Aug 29, 2004 | 03:12 PM
SeanT's Avatar
SeanT
Does it run ok at full throttle and when cold? As my car exhibited similar symptoms - Ford had helpfully pushed the lamdba sensor plug back in but not far enough to make contact
Could be sensor related is my point. Crank position sensor? Coolant temp sensor?
Check the dizzy timing though!
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
