P8 wiring diagram
Old Nov 9, 2006 | 10:41 PM
tim10_10's Avatar
tim10_10
Default P8 wiring diagram
Anyone got a p8 wiring diagram or can tell me what pins on the ecu the tps wires go to?
Old Nov 9, 2006 | 10:43 PM
PROMETHEUS's Avatar
PROMETHEUS
yes and yes
Old Nov 9, 2006 | 10:45 PM
tim10_10's Avatar
tim10_10
Please tell then
Old Nov 9, 2006 | 10:46 PM
tim10_10's Avatar
tim10_10
Well actually I know what pins are used I really need to know what order on the tps plug they go to ecu if that makes sense. Im using a 2wd loom and I know that 2 wires need swapping just cant remember what ones
Old Nov 9, 2006 | 10:47 PM
PROMETHEUS's Avatar
PROMETHEUS
Info is at the workshop, will post in the morning. Can u wait?
Old Nov 9, 2006 | 10:48 PM
tim10_10's Avatar
tim10_10
Yeah thanks alot I think I may have solved it comparing a diagram i have for a group a cossie and 2wd one but rather be sure so any info would be appreciated thanks
Old Nov 9, 2006 | 10:50 PM
PROMETHEUS's Avatar
PROMETHEUS
2wd ones and 4x4 ones are opposite way round if that helps
Old Nov 9, 2006 | 10:53 PM
tim10_10's Avatar
tim10_10
Im using p8 loom pf09 tps and 2wd loom. From what I can make out i need to swap pin 17 and 30 round and the final one on the sensor stays where it is but this is where i wanted to be sure.
Old Nov 9, 2006 | 11:00 PM
PROMETHEUS's Avatar
PROMETHEUS
u got it, leave centre pin in same place and swap outer pins
Old Nov 10, 2006 | 07:10 PM
2001ode's Avatar
2001ode
Hi,
Is it that you looking for ?
Regards
Claude
Old Nov 10, 2006 | 07:13 PM
tim10_10's Avatar
tim10_10
Thank you . I swapped the wires today exactly as per diagram bit of luck i got it right
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
THE RADMAN
Sep 19, 2015 12:57 PM
