anyone running a grs s1 large i/c?
Old Aug 29, 2004 | 10:08 AM
kris's Avatar
kris
Default anyone running a grs s1 large i/c?
was thinking about a grs cooler as there getting a lot of good reports i got a s2 rad an c/c at the mo would a s1 grs go in with a s2 rad if i got the s1 boost hoses?are they as good on the s1 as the s2?(got to get a new turbo first though else i'll fill it with oil)
cheers kris
Old Aug 29, 2004 | 10:35 AM
Oranoco's Avatar
Oranoco
Cliff673200 has a GRS on his S1 and seems well happy with it. Speak to Mr GRS himself as he'll be able to answer any queries you may have
Old Aug 29, 2004 | 01:38 PM
CliffRS4's Avatar
CliffRS4
They are well worth the money and I am very pleased with mine , well worth investing in one for your car
Old Aug 29, 2004 | 05:01 PM
Grahamxx's Avatar
Grahamxx
Default Re: anyone running a grs s1 large i/c?
cheers kris
You’re running a Series 2 rad in a series1 I take it?
Although the series 2 radiator has a smaller surface area the volume is bigger than a Series 1 by nearly 2 litres, surface area is very important though!
How is your rad and charge cooler installed?, as the standard series 1 rad is screw in on the slam panel only, where as the series 2 rad is normal bolted top and bottom
A few questions I know, but this will help me sort your installation out.
Old Aug 30, 2004 | 09:28 AM
kris's Avatar
kris
i had to use the s2 rad as i wanted a water cooled turbo and i hed a s2 c/c off my last car that fell off the road so i used all my s2 pipework and water pump the rad and c/c are bolted together as normal the top pins are slotted up through the slam panel and the bottom rests on the crossmember doesnt sound secure but it dont move but if i got the s1 large cooler i think id have to change to a s1 rad and and rework new pipework
cheers
kris
Old Aug 30, 2004 | 10:37 AM
Grahamxx's Avatar
Grahamxx
cheers
kris
Kris you have a pm.
Old Aug 30, 2004 | 11:42 AM
nigel b's Avatar
nigel b
kris
get done what graham done for me
have his ally rad with 2 pipes welded in for the water cooling on the turbo-but i dont use the water cooling anymore
the i/c fits just in front very tightly
graham
did you get my email a couple of weeks ago?-oil breather+catch tank
Old Aug 30, 2004 | 11:55 AM
Grahamxx's Avatar
Grahamxx
kris
graham
Hi Nigel,
I've just come back from my holiday a couple of days ago,I'll recheck my emails and get back to you, sorry......
Old Aug 30, 2004 | 12:14 PM
Grahamxx's Avatar
Grahamxx
Nigel,
You have an email
155lee
Sep 6, 2016 11:10 AM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
