Omex rev limiter + launch control
Old Nov 8, 2006 | 06:49 PM
Southsidecreations's Avatar
Southsidecreations
Default Omex rev limiter + launch control
Thinking about buying one of these for my Escort rs turbo but not sure if it will work or how hard it is to fit.
anyone know???
Old Nov 8, 2006 | 10:48 PM
Fiecos Dan's Avatar
Fiecos Dan
I've got a omex one fitted.
Easy to fit, just simple wiring.
and recommend it.
Old Nov 9, 2006 | 01:08 AM
SafeChav's Avatar
SafeChav
There is a wire which you have to connect to either say a switch on clutch pedal or a steering wheel switch.
The launch control is set electronically, and when you use full throttle change it cuts down to your preset launch control value, which personally IMO isn't very good.
If you were to buy say an Armtech one, they aren't set digitially, but the launch control and full throttle change operate at whatever the rpm is when the switch is depressed, so the benefit being if you have a very low launch control RPM you could lose out with the way the Omex works.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
