which is best to have???
Are you running standard management?
If so, then i always got told to run standard air box. I just cut the front off mine and use a standard ford paper air filter, works a treat
However i think the difference, performance wise, between using a standard air box and cone filter is so minimal, its not worth worrying to much about
