misfirinig and holding back at 4k FIXED :-)
it is an internitent fault in that just happens every now and then
been told i have a sensor down but was hoping somoe one else could help out
the car doesnt boost right (12 psi) and at 4k youo get such a bad misfire (consatntly) that it feels like car going to shake to bits
but....
if i turn of and turn back on (reset in theory) it clears
been told there is a engine check poinit at 4k
any help[ appreciated, cheers
but....
Hi andy
Ive just this weekend had something very similar happen to mine but not in the turn off then turn on sense.
Mine was only boosting half way round the top section in the middle of the gauge instead of right round to the broken lines, got to about 3.5k - 4k and was missing like mad.... Turns out my actuator wasnt set up right it was running 12 psi and holding 8, it now runs 18psi and holds 17. the damn thing had been superb previously for a good 2 months......weird thing is i hadnt touched a thing under the bonnet (dont you just love cossies)!!! it just went....wouldnt mind but its only been on about 6 weeks as was brand new forge -31
Hope you get it sorted out Andy.
Twinny - there more chance of Andy winning the euromillions than him selling his car of that im quite sure!!!
Originally Posted by Twinny
sell it
The point is you reset the autodiag system when you switch the car off.
that's why it can be 'fine' after but if your ECU goes in limp mode it means that you have sensor failure somewere!
the best way would be to read the default code from the ecu when your stuck @ 4KRPM before stoping the engine
you'll find everything over here to do it (you just need a led, a 1Kohm resitor and a piece of wire)
Or you go to your nearest ford dealer when the car is mad but I would advice to go there and warn them before
sell it
Have you had the multiplug down by the front wing (near the coil) sorted? Mine did exactly the same, we changed every sensor!
Wasnt till Ahmed had it idling on his laptop that they noticed it was the wiring making it go into limp mode.......... Mark was fucking around under the bonnet as Ahmed was checking his laptop!
July1 - where is ths diagnostic port then? and how comes no one else ever checks them................
As you make it sound like a common place to check.
the good old multiplugs that join the car loom to the engine loom are shouting out - have these been chopped out and soldered yet - if not, they need doing - they cause ALL sorts of wierd things to go wrong
Originally Posted by JanDK
The diag plug is located under the left strut reinforcement bracket (at least on LHD cars so you may have to look on the right side too)
so under your bonnet between the left damper top and the wing
you'll find 3 plugs: one for the diag, one to reset the ECU and one for the ABS diag.
to one your looking for has 5 holes with only 3 wires (black with black cover)
the one on top has to be connected to the - of the led and you'll have to connect the 2 at the bottom together..
let me know one you've found if you don't I'll post a pic for you
sorry mate.. it was not my entention to seam mad, just coldnt find this plug!! BUT you have put some light in to it
and I will have a look when the arrives.As you see.. I am danish and drive LHD, so it should be possible to follow your describsion.. I hope
Twinny not going too, but i have copnsidered it buy something else
redrsmk5 it not a Actuator probb mate as it boosts fine majority of the time, just has this intermiten fault
Franco tthank you, much appreciated
cheers everyone,
bborrowinng daz c's code reader tonight, hopefully get an aansswwer
cheers everyone,
PassionFords Creator
very simple.
Its seeing an ecu input error, likely open circuit and is activating the secondary security rev limiter at 4000rpm. It is NOT a missfire its a revlimiter, thats why you cant drive through it...
hi all
i am very interested by this subject and i would like if possible to have more informations concerning this issue, i have the same problem but i check out all sensors and seem in perfect order ,i changed the air temperature sensor ,the map sensor , but the problem still alive ,i used the led auto diag but the eprom has been changed and the auto diag reported code error 43 , did someone know how to disable the limp mode, or can i use a L8 ECU just to check if the problem is coming from my P8 ecu
many thanks for help
Le limp mode et "reseté" ŕ chaque fois que tu coupes le contact mais si ta panne est toujours presente il se bloc immediatement pr te sauver la mise
43 signifie erreur interne si tu as une EPROM autre que celle d'origine c'est normal, sinon c'est probablement ton ECU qui ŕ un soucis.
Si tu as un L8 en version cata tu dois pouvoir le brancher pr test. (a condition que son EPROM corresponde ŕ ta config actuelle...)
also having the same problem at the mo,have changed the multi-plug and it made it a bit better now just every time i start from cold it goes into limp mode,turn it off then on no problems annoying the f**king bejesus out of me
Honestly get yourself a SECS monitor for Christmas
not THAT expensive and every time your switch on you can check ACT, ECT, as well as TPS and MAP is those are fine it only remain the Hego sensor (I personally also have an AFR meter to check it)
It can help a lot to find problems like yours
Another solution is your EPROM support DataStream is to buy (or borrow) a Pectel or Powerchip monitor and see what you can find.
Or maybe book your car to MSD or any good company to make your engine management checked by professionals
big-dirty-dog
not yet
the code reader did not pick up aanything, even though the fault was
happpening, after rough manual diagnostics LOL
bought a throttle position sensor so hoping that will cure it
not yet
what chip are u running?
some chips dont have the built in diagnostic, so wont actually report a fault IF there is one, you could do with swapping ecus or chip with one with a std chip or onw with diag readout enabled...
possible faults that will lock it in 4K LIMIT:
ECT
ACT
Lambda
MAP
dont think TPS does IIRC, as long as it IS giving a reading... but if it revs up, i suspect it is so would be easy to rule out.
lanmda probe connection is a favourite, as is the multi plugs if they havnt been choped out...
ECT
ACT
Lambda
MAP
Dave Henshall
its a MSD chip mate,
it has started to rev funny, when the TPS is diisconnected
some more work will be done, to find the problem
i will spk to my mate about it hopefully, he is very good and i hope
he can help (hi daz)
[quote="AJC"]Dave Henshall
quote]
it will do,, the air is getting in, to allow the engine to rev, but the ecu wont know how to fuel and will be all over, the place - which sounds like it is doing, hence i'd say the TPS is ok.
pretty sure stus chips do have the diag codes, not too sure if they are the same as the ford ones though...? stu?
quote]
Originally Posted by AJC
cheers troops, but this talk getting to technical for me
timee to call in thee calvary i think
i might just start mine up from cold till its warm then turn it off and back on again from the rest of the time i own it
http://www.motorsport-developments.co.uk/pages/iawmonitor.htm
that will sort you out
would love to be able to send it to MSD to get sorted as i dont have to ask daz to help me again or get my hands dirty,
but witht he car having limited use and not being used due to bad weather
im in no rush to fix it
it might end up there, i dont know yet,
C.Lyon that's where the IAW Monitor software comes in. You can run it all the time and do a datalog to see what went wrong afterwards
