One for the header tank spotters
Old Nov 6, 2006 | 01:00 PM
Arfur's Avatar
Arfur
Default One for the header tank spotters
Can some one explain the differences between 2wd and 4wd Saph header tanks, as they look the same to me.
And did early 2wd Saphs come with the three-door-style tank c/w the water level take-off?
Cheers,
Si
Old Nov 6, 2006 | 03:43 PM
Ridgey's Avatar
Ridgey
That was my understanding 2wd and 4wd tanks, due to the slightly different water system and hosing arangements.
Old Nov 6, 2006 | 06:10 PM
B11GNS's Avatar
B11GNS
3dr's and 2wd saph's have the same tanks with the level sensor boss on the saph's blanked off and the water return at the top of the tank. The 4wd and escort ones dont have the water return at the top of the tank, they have it in the place of where the level sensor boss used to be which is below the water level and is larger then the small 2wd one. Yoy cant get the 2wd ones any more but you can get the 4wd ones. I have modified a 4wd one to use with the 2wd application by putting a fitting at the top of the tank and blocking off the 4wd port. I will try to fit the level sensor in the 4wd port at some point.
Old Nov 6, 2006 | 08:33 PM
costina's Avatar
costina
Live long and prosper!!
Read your back issues
c'mon simon get a grip
Paul
Old Nov 6, 2006 | 08:37 PM
Daveesaunders's Avatar
Daveesaunders
As above, I believe Ford used to sell an adapter pipe in order to fit the 4wd tank to the 2wd tank, I had this arrangement on mine when I first got it and I wasn't keen on it as the return was below the water line and after a hard run you could hear the water bubling when the engine was switched off. That problem dissapeared when I fitted the tank from a 3dr as the return pipe is up high.
Old Nov 7, 2006 | 06:23 AM
SteveB's Avatar
SteveB
Both tanks have an extra small outlet for swirl pot connection to the top of tank
4wd....
2wd....
Old Nov 7, 2006 | 01:24 PM
Arfur's Avatar
Arfur
Paul
We've just published issue number 247 - do you really think I can be bothered to plough through all of those?
Cheers for all the replies. Makes sense now.
Old Nov 7, 2006 | 04:14 PM
B11GNS's Avatar
B11GNS
Steve B, the standard ones dont have.
Old Nov 8, 2006 | 09:34 AM
dojj's Avatar
dojj
Resident Wrestling Legend
first thing i did when i got my bailey tank was to get one with a level sender fitting in the side
unpluged the low washer fluid gizmo and plugged it into the side of teh header tank instead
gave me at least 2 warnings when i'd dumped all my water so was worth the cost of extending the wire just a little bit
Old Nov 8, 2006 | 01:02 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
best way to know is the 2WD has a lil hole at the top for the turbo water pipe,and the 4wd one has 2 biggens!
Old Nov 12, 2006 | 07:40 AM
bige's Avatar
bige
if you see closly too the right - its an orginal Wolf presure botle .
Wolf stated - when they raced 2wd they had problem with cooling down turbo - they solved the problem with this = 4x4 ford botle in the future .
Nov 1, 2015 06:53 PM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
