Cosworth Co% level,help please
Old Aug 28, 2004 | 02:31 PM
CosKev3's Avatar
CosKev3
Default Cosworth Co% level,help please
The level at idle won't come down below 9%,had m8 check it last week and would'nt go below 10% so fitted a new coolant temp sensor as the screw on ECU did'nt make any difference to levels
Have been told you can reset the mixture screw pot by turning screw 4 turns in then 4 turns out then 2 turns back,supposedly this resets it???
Could this be a chip problem,or is there anything else I can check/replace that would affect fueling?
Any help appreciated
Old Aug 28, 2004 | 03:43 PM
DazC's Avatar
DazC
Might be a mapping issue, could be a map sensor issue...there are a few variables. I would get it to a tuner asap before you suffer from bore wash...
Old Aug 28, 2004 | 04:11 PM
TIFF's Avatar
TIFF
Chasing Radders
As Daz said, get a tuner to take a look.
Mess with it yourself and you could end up with an engine from Cadburys
Old Aug 28, 2004 | 04:14 PM
GARETH T's Avatar
GARETH T
are you sure there isnt a brake in the wires going too the coolent sensor?
i can tell you the pins if needed so you can measure the resistance with a multimeter!
is the engine hot enough? has the fans come on?
gareth
Old Aug 28, 2004 | 04:19 PM
CosKev3's Avatar
CosKev3
gareth
Yeah was hot m8,don't own a multimeter
DazCoes the MAP sensor affect the fueling on tickover?
If so have got a spare 3-bar so could try that!
Old Aug 28, 2004 | 05:04 PM
DazC's Avatar
DazC
gareth
It effects the fueling all over. It is the main sensor the ECU needs to calculate fueling. The ECT sensor has influence on this though...
Old Aug 28, 2004 | 06:39 PM
CosKev3's Avatar
CosKev3
Nice 1 DazC
Will give my spare 3 bar a go 2moro,will check connections/earth to it too
Will running it at 9% Co give me bore wash?
Old Aug 28, 2004 | 07:10 PM
DazC's Avatar
DazC
Yes. It's far too rich besides being highly illegal...
Old Aug 28, 2004 | 08:40 PM
the saint's Avatar
the saint
when my cars co was that high it was the map sensor at fault plus the fuel pressure regulator was at 4 bar which is way too much..............
Old Aug 28, 2004 | 09:03 PM
CosKev3's Avatar
CosKev3
Cheers,will bang sensor on and get m8 to check fuel pressure
Old Sep 11, 2004 | 01:41 PM
bbigman2000's Avatar
bbigman2000
did you get it sorted mate ?
Old Sep 11, 2004 | 04:15 PM
CosKev3's Avatar
CosKev3
Not yet
Tryed diffrent MAP sensor,no joy
Found fuel press reg was'nt working as it should be,took vac pipe off and pressure
did'nt rise!
Could have been costly on a long flat out blast
Got a chip on way so going to try that(cheers RS Gus)
Old Sep 11, 2004 | 04:17 PM
john's Avatar
john
Hope you enjoy the chip m8 came out my car
Old Sep 11, 2004 | 04:19 PM
Gavin E-Cos's Avatar
Gavin E-Cos
Kev, I had a simalar problem, take a look at this link.
http://www.rsnorfolk.co.uk/Useful%20Info.html
It worked for me.
Gav
Old Sep 11, 2004 | 04:34 PM
CosKev3's Avatar
CosKev3
Cheers m8.Hope you sort your motor soon.Bargain priced chip though
Old Sep 11, 2004 | 04:37 PM
CosKev3's Avatar
CosKev3
It worked for me.
Gav
Cheers m8,think your Esc Cos has got a lot more advanced ECU than
my old L6
P8 ain't it in Esc Cos????
Be worth a try I suppose.
Old Sep 11, 2004 | 04:47 PM
CosKev3's Avatar
CosKev3
Be worth you trying that link bbigman2000
Old Sep 12, 2004 | 12:49 PM
Gavin E-Cos
Yes it is P8,
hope you get it sorted.
Gav
Old Sep 22, 2004 | 05:29 PM
bbigman2000
I got mine sorted out bud its an L8 ecu in mine, jsut adjusted the co screw in a little and shes running and idling mint now, havent got A co meter but will take it somewhere soon and have them set it properly
Old Sep 22, 2004 | 06:20 PM
Cossie-Spen's Avatar
Cossie-Spen
mines doing the same ...need to find tuner local ish quick
Old Sep 22, 2004 | 07:03 PM
CosKev3's Avatar
CosKev3
Mines sorted at last
Back on the road
It was the ECU that was fooked in the end,thank you for everyones input
Bought myself a multimeter and checked all resistances on sensors and earths etc on ECU plug,meter was £8,well worth the money
Thanks also to MSD,very helpfull and freindly advice over the phone
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
