sierra cosworth rear calipers
Old Nov 4, 2006 | 10:57 AM
16vzetec's Avatar
16vzetec
Default sierra cosworth rear calipers
i have a sierra rear disc conversion.
i have a problem with the back end coming round.
the car has extra rear line restrictors to try and help it but it still does it.
one thing i have noticed is the rear brakes drag even when pushing car on the drive.
i recon the pistons are not releasing when breaking.
the thing is the calipers were striped and are like new.
but what i cant understand is the sierra rear caliper has a spiral shaft on which the piston screw on.
i tried pushing pads back but the shaft doesnt let the pistons go back like front calipers.
you have to have a special tool to wind the pistons back in.
has anyone else had these problems or know whats going on here?
Old Nov 5, 2006 | 12:00 PM
SafeChav's Avatar
SafeChav
You sure you haven't over adjusted the handbrake cable and its partially on all the time?
Also you haven't played with the nut inside the servo like many people suggest have you?
You do have to wind the pistons back, thats the same for the majority of cars with calipers on the rear. You can usually just use a screw driver in the slot to spin it round
Old Nov 5, 2006 | 08:43 PM
16vzetec's Avatar
16vzetec
handbrake is loose.
no playing with servo.
dunno whats going on.
Old Nov 5, 2006 | 08:46 PM
allbluepete's Avatar
allbluepete
what brakes you got on the front bud?
Old Nov 5, 2006 | 08:49 PM
SafeChav's Avatar
SafeChav
Have you got the notch on the pads located correctly in the pistons?
james kiely
Aug 28, 2015 08:58 PM
charliecosworth
Aug 19, 2015 02:00 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
