Help please!!! Problem with me car!!??!! nasty oil leak :(
Old Aug 28, 2004 | 12:22 PM
B13F RS's Avatar
B13F RS
Default Help please!!! Problem with me car!!??!! nasty oil leak :(
I found a nasty oil leak coming from around the breather that is situated underneath the inlet manifold and on top of the engine mounting.
What is the black box thingy called?? it has a pipe coming out the top to my oil separator.
Is it mounted into the block?? by an o'ring or sumat??
Has anyone ever done one??
Sorry for the thousand Q's but i can't see fook all and its defo coming from that cause the oil is coming down in between the four bolts for the engine mounting.
Old Aug 28, 2004 | 12:42 PM
Dilly's Avatar
Dilly
the black thing is a flame trap, comes from the sump. don't think there is any o-rings
Old Aug 28, 2004 | 01:01 PM
B13F RS's Avatar
B13F RS
thanks mate, have ya ever had one out?? does it just pull out??
Anyone else had any experiance with this??
Old Aug 28, 2004 | 01:08 PM
bob s2zvh's Avatar
bob s2zvh
yeh had the same problem fitted my t34 and mongoose exhaust,so thought i'll change oil and filter 2! filled with mobil one motorsport cost Ł47 for oil! went to crail the next! did 18 runs managing best time of 13.6!not bad for stg 1! thought it would be senible to check the oil before driving home! to my surprise none showing on the dip stick!it had all been blown out the same place as urs and under the car what a mess!i knew i should have spent the extra hour it fitting the breather kit that was sitting in my boot! Plus won't be using mobil oil again! as i never had this problem usuing castrol rs!
Old Aug 28, 2004 | 01:23 PM
B13F RS's Avatar
B13F RS
Did you take the flame trap out bob? that sounds like a nasty experiance you had there mate
Old Aug 28, 2004 | 02:21 PM
bob s2zvh's Avatar
bob s2zvh
no i havn't yet! but my bailey breather does away with it!luckily didn't cos any damage!just a mess!
Old Aug 28, 2004 | 02:33 PM
Dilly's Avatar
Dilly
i think they just pull out of the bottom breather hose but you aint got much room with the inlet in the way. maybe you could disconnect the breather hose at the sump
st220kyle
16
Aug 14, 2015 06:13 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
taylora1409
Aug 12, 2015 12:06 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
mattman1234
24
Aug 1, 2015 11:46 AM
