Series 2 Header Tank
Anyone know why they expand
When i bought my series 2 the header tank had expand and my mate gave me a brand new header tank from fords so i fitted that and now thats split its only been fitted a couple of months
Anyone know why they keep expanding????
Brian
Brian
Originally Posted by Brian
Its the old cap
It is using a bit of water but have no leaks there is no water in the oil
Brian
Brian
If your losing a bit of coolant aswell.............
Compression test and leak down test can never go a miss!
Its the old cap
Brian
Brian
Will get a compression test done on saturday
Brian
Well done a compression test and a leak test light night and its fine
All have done is fitted the old header tank and the old cap which is red while the cap on the new header tank that split was yellow
Done about 100 mile today and hasnt used any water
Brian
Brian
Originally Posted by Christian and Beccy
You should also test for Hydrocarbons in the water. Can be done with an Exhaust gas analyser.
Brian
Kiran1600E
11
Oct 2, 2015 11:35 AM
