saff gauges voltage regulator?
Old Oct 31, 2006 | 01:06 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default saff gauges voltage regulator?
do saffs have a voltage regulator on the fuel and temp gauges?
My fuel gauge seems to pulse ,and the temp gauge is low
ive swapped them for another set and still the same.....
Old Nov 18, 2006 | 08:06 PM
trevCOSS's Avatar
trevCOSS
my fuel gauge always seemed a bit irregular and had a mind of its own, I suspected something like voltage problems but it turned out that the float was half full of fuel having quite an effect on the gauge
Old Nov 19, 2006 | 03:46 PM
JTECH James
Passion for Fords!
its strange ,the gauge works, but sometimes it jumps about like the gauge is shorting out or something ,i changed the dash and its still the same,
Old Nov 19, 2006 | 06:21 PM
Wardy257's Avatar
Wardy257
They have regulators on the back of gauges, so no need to take instrument cluster apart, just the dash.
Old Nov 19, 2006 | 07:32 PM
trevCOSS's Avatar
trevCOSS
so it cant be the regulator if jtech has already swapped the whole clock set and still has the same issue?
Old Nov 19, 2006 | 09:52 PM
Daveesaunders's Avatar
Daveesaunders
Dodgy earth?
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
