can you get wheels machined to reduce the offset?
Old Aug 27, 2004 | 02:40 PM
Jim Galbally's Avatar
Jim Galbally
Default can you get wheels machined to reduce the offset?
could i get my escos rims machined so that they fit a cossie PROPERLY ie correct offset etc. ?
or is this either impossible or a big no-no?
Old Aug 27, 2004 | 02:43 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Jim,
Is possible, BUT ONLY if there is enough meat on the wheel / strength left to do this. Wouldn't advise taking off any more than a few mm as you also need clearance on the brakes which is quite tight on the Escort rim...
Old Aug 27, 2004 | 02:53 PM
Jim Galbally
so thats a yes its possible, but no dont bother yeah?
cheers mike
Old Aug 27, 2004 | 02:55 PM
Nath's Avatar
Nath
I personally wouldn't bother as its too much aggro. Get the Mondeo/Escort Si wheel if you like them. I do think Esc Cos wheels look the nutts on Saffs though
Old Aug 27, 2004 | 02:56 PM
cossymad's Avatar
cossymad
NO unless you fill the bolt holes then re-drill them shallower
Leave them....they look
Old Aug 27, 2004 | 02:59 PM
Thrush's Avatar
Thrush
Irritating c........
It's true jim - the EsCos rims look as if they were MADE for the Sierra's - Saff and 3dr's, and would look odd if you pulled them in a bit.... Jsut get some decent tyres so no rubs and leave it
Old Aug 27, 2004 | 03:14 PM
Spiky's Avatar
Spiky
Old Aug 27, 2004 | 03:52 PM
MWF's Avatar
MWF
Jim take a look at that maroon sierra hatch with the cossie YB conversion that does track days. That has 16" Esc Cos wheels and the owner has had the front arches rolled and 'pulled' so the wheels look right. You really wouldn't notice till someone points out the arches come out from the car a bit more.
Old Aug 27, 2004 | 04:13 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Jim,
Whats the problem? Do you find the wheels stick out too much or are they rubbing? My escort cossie wheels don't rub at all with 215/40/16 tyres but they do stick out beyond the arches but about an inch! Makes it look a bit like a monster truck!
Old Aug 27, 2004 | 04:14 PM
Jim Galbally
i just got warned that they can cause wheel bearings to fail n cock up the handling...
Old Aug 27, 2004 | 04:23 PM
Kev H's Avatar
Kev H
Mines the same 215/40/16 tyres, and i aint got no problems with them.
Oh yeh they only clear the calipers by about 2-3mm so i wouldnt machine them!
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
