N/A CVH and RST CVH
What differences there are between these two engines? I know that RST has low comp pistons and sodium filled valves. Is there anything else that differs from other CVH engines like xr3 or 1.4i ?
Originally Posted by Rick
the turbo block has an oil return. Obviously 1600 blocks are different from other capacities.
RS Turbo's dont have sodium filled valves!
Mfi cams are the same in N/A and forced induction, as are the cams in EFI N/A and forced induction.
Fitting a later EFI cam to an earlier MFI engine will see slight power gains.
mk3ste
Oct 17, 2021 10:09 AM
