Help!!!!!!!!!!!!!!
My dash lights and back lights are not working on my car and I need to get it sorted asap!!!!
Anyone able to help me I thought it might be the fuses but it's not!!!!
It's an XR3i 93
It's an XR3i 93
Sounds like it could be the column mounted stalk.
IIRC, that was a bit of a common problem on the MkV and V1 Escorts....
Saying that anna if you need the car before ya can fix it try flicking the switch for the lights back and forth and they should work as mine did, cheers, Grant
I also reckon it will be the indicator / light stalk on the column!
My girlfriends sister's L reg escort has the very same problem you describe - new stalk sorted it!
RichardPON
Rick
Fuses are all checked and fine my live-in mechanic checked them this morning.
XR3I 130
I sat there for ages last night doing that someone thought I was flashing them.
Gunna get a new Stalk as this seems to be the problem then
Rick
XR3I 130
