Anyone on here help/know of anyone that can (fabrication Q)
Old Oct 26, 2006 | 09:45 AM
jr's Avatar
jr
Default Anyone on here help/know of anyone that can (fabrication Q)
basically got a upper inlet manifold (not ford) thats been made simply out of 4mm Mild steel box section for a project, got all the bits to do it bar the actual cutting out of the ports for the lower inlet which bolts to the head
tried a few companies locally, but they can cut the ports, which are oval, which match up to the lower inlet (got a gasket as a guide for it)
as they reckon plasma cutting wont work ?, and to cut them out manually is going to be a nightmare ?
any ideas
jr
Old Oct 26, 2006 | 09:56 AM
Garage19's Avatar
Garage19
4 mm wall steel box! What you building a tank?
Draw the shapes on and the use a series of drill holes around the egdges and then file to final shape.
Or...
Ditch the heavy steel bit and get a nice ally bit knocked up. Could be welded on then.
Old Oct 26, 2006 | 10:01 AM
jr's Avatar
jr
it might not be 4mm, it could be 3, problem is people have made these before and when tightning them down on the lower inlet they have deformed on cheap/thin versions
if it works there will be an alloy one, just need to try this first
had considerd the drilling holes and filing them, but thought there might be an easier/neater way
Old Oct 26, 2006 | 10:58 AM
scruffythefirst's Avatar
scruffythefirst
Drill the holes and then use a die grinder / deremel. Beats a hand file any day.
Old Oct 26, 2006 | 11:01 AM
cossie350's Avatar
cossie350
Have it lazer cut, take your gasket with you and they will draw it up on CAD, i live in the arse end of nowhere and there are 3 companies within 20 miles of me that do it, so where you are you shouldnt have much trouble
Old Oct 26, 2006 | 11:11 AM
MOONDUST FRST's Avatar
MOONDUST FRST
Mark out shapes, drill as big a hole as possible but smaller than the port size, then hit it with the die grinder fitted with tungsten carbide cutting tool. will rip through in no time most sheet metal firms can do this
steerfromdarear
28
Jan 29, 2016 06:14 PM
jc1989rs
Sep 18, 2015 07:05 PM
Brian
Sep 11, 2015 08:06 AM
Benn 304R
13
Aug 28, 2005 11:02 PM
ProjectBobcat
18
Feb 9, 2005 08:29 PM
