OFFSET FOR A SAFF
What is a standard 2wd offset on a saff cos
What will 38mm offset in a 7 by 17 be like on my cosworth
Finally is a 2wd saff stud and nut or bolt fixing
Thanx in advance
PS my cars in the painshop so I cant check
Si
Thanx in advance
Si
Originally Posted by Bosch-Man
Std is 38mm i beleive...i went ET35 x 7inch on my Cossies cause they then fit over big brakes plus they look better IMO.
Stud and nut fixing.
I take it then that a 38mm wheel will sit out less
Si
I had 17" x 7" wide with ET42 (came on car) and imo looked crap... I bought some 20mm hubcentric spacers (for the rear left front std) and that filled the archs just right...
cossie330
Oct 7, 2015 08:22 PM
