FAO Anyone Using a Bias Pedal Box + Hyd Hbrake??
Got a bias pedalbox and hydraulic handbrake, gotta order the fittings from Rally design,
fronts are straight forward but unsure of piping hyd handbrake up,
outlet from cylinder threw handbrake to t to rear calipers??
or a resovior ontop of handbrake and tinto rear line from m cyl with a one way valve?
pipework is:
Rear master cylinder to Rear of hydraulic handbrake,
Front of hydraulic handbrake to `T` piece then each side of the T to the rear brakes
The pics above are of mine (with the bias sensor in line)
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
