Who can shorten cossie rear driveshafts
which company can do this?
and is it by cutting/sleeving the shafts
or by doing it correctly by shortening the shafts and then re-machining the splines
or even better are there any other shorter ford shafts that fit, such as front driveshafts off something?
cheers
cheers
Just had one apart and it can't be re-machined, as after the splines it goes narrower
so weld it is
how much play should there be along the axis of the shaft
a) at ride height driveshaft level
b) at full droop?
anyone?
cheers
so weld it is
b) at full droop?
anyone?
cheers
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
