Which head gasket for a cosworth
Old Oct 25, 2006 | 11:37 AM
Gary F's Avatar
Gary F
Default Which head gasket for a cosworth
Ok my headgasket seems to be fooked so which headgasket should i go for? I had a group a but thats only lasted a few month.
I've head people saying they use wrc 1's but £375 seems a bit steep or am I just being a tight cunt
Old Oct 25, 2006 | 11:45 AM
SapphyMike's Avatar
SapphyMike
if you use ANY metal gasket (WRC or Cometic), then you WILL have to have the head and the block face machined so that they are 100% flat.
the fibirous gasket (group a) will help "mask" any imperfections in the head or the block face, but a metal one cannot.
how much boost do you run and are you sure the gasket was fitted correctly the first time, as i ran a standard YBP head gasket for over a year with no problems at all, at 20psi on a T34.
Old Oct 25, 2006 | 11:48 AM
CosKev3's Avatar
CosKev3
Got a WRC one on mine at the minute,they are supposed to be re-useable,would/has anybody re-used them??????
Saw these copper ones on E-Bay,anyone used them:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
Old Oct 25, 2006 | 11:59 AM
SapphyMike's Avatar
SapphyMike
i'd never reused a gasket.
when its been torqued down it does squash, therefore no matter what gasket it is, it will not be the shape it needs to be.
if you blow a metal gasket, your block or your head has an imperfection on its face.
Old Oct 25, 2006 | 12:06 PM
STUCOS's Avatar
STUCOS
Also depends are you on standard head bolts,if so stick with group a or copper,multi layer more suited to long studs
cheeRS stu
Old Oct 25, 2006 | 12:08 PM
Gary F's Avatar
Gary F
Mike I'm peaking 29psi thing is probs hasn't been fitted properly cos the lad who done it turns out to be a fookin cow boy so do you think a group a should do the job?
Old Oct 25, 2006 | 12:09 PM
Gary F's Avatar
Gary F
yeah standard headbolts
Old Oct 25, 2006 | 12:26 PM
Gary F's Avatar
Gary F
bttt cos i need to order 1 asap
Old Oct 25, 2006 | 12:28 PM
Jay,'s Avatar
Jay,
Sponsor
ive run 32 psi ona group a with a t34 for nearly a year not advisable but its done it lol
best thing u can do is get it stripped check the block with a proper straight edge and head then use a cometic stu@motorsport developments swears by them
Old Oct 25, 2006 | 12:30 PM
Jay,'s Avatar
Jay,
Sponsor
buy the way thatts holding 27 psi till the rev limit at 7500
Old Oct 25, 2006 | 12:32 PM
Gary F's Avatar
Gary F
I've just realised that I can get a Cometic 1 for £120 so will I need the head checked
Old Oct 25, 2006 | 12:34 PM
R4N SS's Avatar
R4N SS
i got a WRC multi layer on mine and never had any probs.
..with all metal gaskets you should use wrc long stud or at the very least a arp stud/nut kit...you require a greater clamp.
My 600bhp lump runs WRC long stud and cometic gasket
My DIY engine runs WRC long stud and WRC gasket (500bhp)
My runaround runs a Grp A and wire rung block (350bhp)
Fuck coopers rings right off
Old Oct 25, 2006 | 12:36 PM
Jay,'s Avatar
Jay,
Sponsor
yes and a mega clean block checked with a straight edge normally block are very straight but get it checked
Old Oct 25, 2006 | 12:37 PM
Gary F's Avatar
Gary F
Well mines only stage 3 don't know what to do now
Old Oct 25, 2006 | 12:41 PM
Jay,'s Avatar
Jay,
Sponsor
advice given man just check both faces then put a cometic on if its ok
Old Oct 25, 2006 | 12:45 PM
Gary F's Avatar
Gary F
cheers jay next question is how will i get it checked a garage is doing it so will they be able to check it or is it a specialist thing
Old Oct 25, 2006 | 12:48 PM
Jay,'s Avatar
Jay,
Sponsor
they need a total flat edge and feeler gauges will do it corne to corner and straight down the middle but if a garage is doing it they should already no how to lol
Old Oct 25, 2006 | 12:49 PM
Gary F's Avatar
Gary F
Cheers Jay
Old Oct 25, 2006 | 01:03 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Cometic headgakset will be fine. see my sig for my engine spec
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
mrknifey
Aug 30, 2015 11:48 AM
turbotrev
Aug 22, 2015 11:41 AM
Aug 14, 2015 07:29 AM
