Fitting 4wd camshaft on 2wd head
Old Oct 25, 2006 | 07:20 AM
2001ode's Avatar
2001ode
Default Fitting 4wd camshaft on 2wd head
Hi,
Is it possible to fit 4x4 camshaft on 4x2 head, and how to do ?
Thanks for info.
Regards
Claude
Old Oct 25, 2006 | 07:23 PM
cozzierich's Avatar
cozzierich
4x4 cams can be used in 2wd applications with the use of a YB0970 cam spacer. I am not sure if the spacer is still available from Cosworth.
You could also machine a spacer, but I do not know the spec offhand. Someone else may be able to answer this.
Old Oct 25, 2006 | 09:11 PM
cossie604's Avatar
cossie604
Ive got a pair of brand new un-used Burton spacers that I bought in error (I was led to believe that the cams I was buying were originaly 4x4...turns out they were 2wd so spacers no longer needed). If I remember rightly they are around a tenner each plus postage from Burton so you can have them for 12quid all in if your interested.
Stu.
Old Oct 25, 2006 | 09:13 PM
cossie604's Avatar
cossie604
lol just noticed your from paris....i'd have to check postage mate, they would be 10pounds plus p&p if you wanted them.
Old Nov 13, 2006 | 03:31 PM
2001ode's Avatar
2001ode
Hi Stu,
You have a PM
Claude
RUBY123
Oct 22, 2023 12:04 PM
3i Jim
Nov 20, 2015 05:12 AM
turbotrev
Aug 22, 2015 11:41 AM
markk
18
Aug 17, 2015 05:19 AM
lockie
Jul 31, 2015 10:03 PM
